Oudere Marklin S3/6 opleuken
hmmglaser
om 00:18:17
om 00:02:10
29 January 2026, 23:52:57
reinderlf
29 January 2026, 23:21:21
29 January 2026, 23:18:11
reinderlf
29 January 2026, 23:13:59
29 January 2026, 23:08:32
meino
29 January 2026, 23:00:52
29 January 2026, 22:34:20
Dirk
29 January 2026, 22:34:00
29 January 2026, 22:29:42
29 January 2026, 22:27:19
29 January 2026, 22:20:32
BrightonBelle
29 January 2026, 22:20:11
29 January 2026, 22:05:05
Stub switches
29 January 2026, 22:02:56
marctrein
29 January 2026, 21:41:24
29 January 2026, 21:28:18
weslyr
29 January 2026, 21:11:59
Vroeger
29 January 2026, 20:55:42
Gare de Tannay, Frans N-spoor
Rik
29 January 2026, 20:52:30
29 January 2026, 20:46:35
Modelspoorbeurs MSC Spijkspoor 7 februari 2026
Suchet
29 January 2026, 20:11:43
29 January 2026, 19:59:56
Igra model 2026
TGVfreak
29 January 2026, 19:55:08
Oosthoek
29 January 2026, 19:32:06
Slijptrein
29 January 2026, 19:31:43
Mte korting
barry1972
29 January 2026, 19:10:50
Steven Loosman
29 January 2026, 18:35:56
29 January 2026, 18:27:54
Baantje in lente-achtig landschap
Topic: Baantje in lente-achtig landschap (gelezen 19422 keer)
Ric
Re: Baantje in lente-achtig landschap
Reactie #45 Gepost op:
27 November 2021, 11:22:08 »
Jos, dank voor de duidelijke uitleg en dito foto's
Grt. Ric
grove den
Modelboombouwer
Reactie #46 Gepost op:
30 November 2021, 19:36:32 »
En weer wat graspolletjes/vezels en meer dan 50 struikjes en klimopjes geplant...
Jos
natuurlijk kunstboompjes
http://mbbgroveden.com/
Reactie #47 Gepost op:
30 November 2021, 22:31:53 »
Als ik het goed zie dan is 1 van de dingen die leiden tot succes is de enorme veelheid van de verschillende plantjes. Waar ik met 6 struikjes van dezelfde kleur mezelf al goed bezig vind is dit toch heul wat anders.....
Albert
https://denapp.blogspot.com/
T.Spat
Reactie #48 Gepost op:
30 November 2021, 23:06:47 »
Tuinieren in HO...
grove den
Modelboombouwer
Reactie #49 Gepost op:
30 November 2021, 23:07:31 »
Nou Albert.... het is ja en nee....
Ik worstel hier ook mee. Moet je nu een diversiteit aan struiken laten zien en/of elke struik "apart"?
In de natuur lijkt een "struweel"/rij natuurlijk wild groeiende struiken bij elkaar ,natuurlijk op een afstandje!, het merendeels een vrij aaneengesloten vorm. maar hoe dichter bij je komt hoe diverser de vormen en contouren.
Misschien omdat het baantje zo klein is dat ik onbewust gekozen heb voor de "dichtbij"benadering. Met die verstande dat de struiken allemaal , bijna, dezlfde basis als "geraamt/opbouw hebben. Ik varieer in kleur van de takken, wat tinten en grootte van de lichtgroene blaadjes .
Wat mij ook bezig houdt is het licht ....lente licht?
de zon is al wat feller maar nog pas de helft van de hoogte boven de horizon als in de zomer dus meer licht "van opzij" , minder zware slagschaduwen als in de zomer en vooral helder licht.
Zag in het draadje van Heilan Ware van Hendrik Jan, de 4 jaargetijdenmodules in Schotland dat hij daar ook mee bezig is....vooral... nee ook de herfstfoto/belichting /kleuren/achtergrond is schitterend.
grove den
Modelboombouwer
Reactie #50 Gepost op:
30 November 2021, 23:12:03 »
Tja Tis....als je beroep hovenier is......
en de kunstakademie "gehad hebt".....= verven met struikjes.....
Jos
Laatst bewerkt op: 30 November 2021, 23:28:37 door grove den
Reeks77
Rhb is Cool !! HOm Bernina
Reactie #51 Gepost op:
01 December 2021, 08:35:24 »
Dan kunnen we elkaar een spreekwoordelijke hand geven !!
grove den
Modelboombouwer
Reactie #52 Gepost op:
06 January 2022, 17:01:02 »
Na een maandje in de - corona- lappenmand te hebben gezeten weer langzaam verder met het baantje.
Het is nu meer details aanbrengen en steeds meer vegetatie.
Heb de afgelopen week 3 A-viertjes( +/- 90stuks) met struikjes geplant op het talud t.o het station en verschillende grotere bomen/struiken.
Ook gestart met de stationsomgeving . Eigenlijk nu allemaal - prettige- "priegeldingen" om te doen maar die tijd opslokken...maar ja dat is bekend.
Jos
Patrick1975
Reactie #53 Gepost op:
06 January 2022, 19:00:40 »
Das minder Jos, gelukkig ben je het hovenieren niet verleerd.
Zie weer uit naar de vorderingen
Gr.Patrick
Reactie #54 Gepost op:
06 January 2022, 19:43:26 »
Had dit draadje nog niet eerder opgemerkt.
Heel mooi werk, Jos
Groet, Bas
DJV
Reactie #55 Gepost op:
06 January 2022, 22:37:38 »
Sfeertje weer
Groeten Dirk Jan
V100 "manusje van alles".
Ruben1990
Reactie #56 Gepost op:
06 January 2022, 23:51:57 »
Wat schitterend! Hulde
Ric
Reactie #57 Gepost op:
07 January 2022, 10:58:11 »
Jos, ik miste je vorderingen al. Een goed herstel toe gewenst.
Grt. Ric
grove den
Modelboombouwer
Reactie #58 Gepost op:
09 January 2022, 16:33:01 »
Dank jullie wel!
Planten die ik 2 jaar geleden "besteld heb" zijn geleverd en heb ze meteen geplant: ideaal plantweer!
Voordeel van deze bomen : ze hebben geen boompaal nodig en plantgaten zijn max 2 mm in doorsnede....
Voor alle duidelijkheid: dit is een opdracht. Het baantje is mij aangeleverd in 4 grote kisten van 200 x 70 x 60 cm. Het bestaat uit 5 delen en de platte "segmenten" gemaakt van 6 en 9 mm triplex , met de rails erop bevestigd met een kurkbedje van 2 mm dikte
Ik had gehoopt op , minimaal het dubbele....
de stevigheid liet te wensen over... heb dus in elke hoek een verstevigingsrib geplakt /geschroefd. Toen ik de segmenten in het begin optilde/verplaatste dan hoorde je de houtlijm tussen de plaatjes triplex kraken/breken/knappen ...
Nu zijn ze wel nog letterlijk flexibel maar je hoort nu niks meer als je ze moet verplaatsen/optillen. Heb ook geen H0 materieel...dus geen locomotief of wat dan ook. Alleen een wagonnetje aangeschaft als referentie.
Dus zal dan ook merendeels een "kale" baan blijven alsof de lijn bijna wordt opgeheven met per week maar een trein vanuit ergens naar/langs dit stationnetje. En ik ben net altijd te laat om die op de gevoelige plaat te krijgen
Jos
Jos
Laatst bewerkt op: 09 January 2022, 16:46:22 door grove den
DJV
Reactie #59 Gepost op:
09 January 2022, 16:52:11 »
Alles is hier ook zo mooi groen.
Groeten Dirk Jan
