Ontraxs 2026 door Frank 123
Vandaag om 07:50:06
Vandaag om 04:37:58
Pfarrerwinkel bahn door DJV
Vandaag om 02:45:23
Vandaag om 02:43:24
Modelwensen 2026 door Harander
Vandaag om 00:07:39
Roco 42616 door johan george
Vandaag om 00:05:28
25 December 2025, 22:51:08
25 December 2025, 22:51:02
Even voorstellen Niels uit Den Haag door RallyAstra
25 December 2025, 22:47:57
25 December 2025, 22:43:54
25 December 2025, 21:42:58
25 December 2025, 21:32:35
Yamorc 7001 dood door Reinout van Rees
25 December 2025, 21:16:47
sluitverlichting op paar goederenwagens 3 rail door bellejt
25 December 2025, 21:05:38
25 December 2025, 20:31:55
Berkina Volvo met Viessmann taxi bord door ruudns
25 December 2025, 20:03:34
25 December 2025, 19:32:29
25 December 2025, 19:00:51
Laatste beurs voor Piet Peetoom (Godfather Models& Supply) 10/11 januari a.s. door Ronald Halma
25 December 2025, 18:27:52
25 December 2025, 17:51:59
25 December 2025, 16:50:11
Goede wensen voor 2026 door Wim Vink
25 December 2025, 16:15:16
MoBaBro.de door Marco1044
25 December 2025, 15:52:36
Van Eijs naar Wijlre en naar Schin op Geul door dennie
25 December 2025, 15:44:20
Treinverkeer in het oostblok, grensoverschrijdend? door Benelux795
25 December 2025, 15:31:10
25 December 2025, 14:58:44
Combine als lading: welke wagon geeft het beste resultaat door DJV
25 December 2025, 14:51:13
REE Modèles 2022, nieuws van de fabrikant. door kar
25 December 2025, 14:14:55
Molendaal, h0-baan, Nederlands tintje, Periode III-heden. 2,6x1,4m door Juroen
25 December 2025, 13:16:54
25 December 2025, 12:58:11
Auteur Topic: Snot!!!!!  (gelezen 5469 keer)
    • sleutelspoor
Snot!!!!!
« Gepost op: 06 May 2010, 19:23:06 »
Liquid Plastic Traction Tire for Locos 1 Ounce Bottle
Walthers Part # 174-1
A scale, $24.95, currently in stock at Walthers
[/sup]Increase the Pulling Power of Your Engines
Got a loco that can't get a grip? Bullfrog Snot provides a quick and easy way to improve the pulling power of HO, N or Z Scale engines - without taking them apart!
Simply power up your loco so the wheels spin slowly and apply a light coat to the wheel/s on the geared axle. Allow it to cure (Bullfrog Snot dries at room temperature), and prepare to be amazed the next time you run your model! Great for engines that didn't come with traction tires, it can also be used to replace old, dried-out or missing tires on your motive power too.
Bullfrog Snot comes in a handy one-ounce jar, and is ready to use.
« Laatst bewerkt op: 07 May 2010, 00:00:16 door Sobat Kras »
**Jelle**
Re:Snot!!!!!
« Reactie #1 Gepost op: 06 May 2010, 19:35:34 »
't is maar goed dat het geen 1 april is............... :o
Ik vraag me af hoe het dan met de stroomafname zit. Is dit snot electrisch geleidend?
Jelle.
NS, DDW, Edits booster, LocoNet met LbServer, besturing met eigen geschreven software in VB
GD
  • Nee hoor, die heb ik al heel lang...
Re:Snot!!!!!
« Reactie #2 Gepost op: 06 May 2010, 19:37:17 »
Je zou je neus op de rails kunnen leggen om het te proberen  ;D
Gerard
Gripen
Re:Snot!!!!!
« Reactie #3 Gepost op: 06 May 2010, 19:53:38 »
Er staat ook bij dat je het alleen op de aangedreven wielen doet, anders heeft het sowieso geen zin. Antislipbandjes zijn toch ook niet geleidend?
H0 - Multimaus - Tillig Elite - TP I-V
MMTB
    • Rheinberger Strassenbahn Betriebe
Re:Snot!!!!!
« Reactie #4 Gepost op: 06 May 2010, 20:59:51 »
Als je op internet rondzoekt, dan kom je heel wat positieve reacties tegen vanuit de VS. Het wordt voornamelijk gebruikt bij spoor N locs en je kunt het zien als zelfgemaakte slipbandjes. Het voordeel van deze snot is dat het geen rommel achterlaat op de rails, wat je anders wel met de rubbere bandjes hebt.
Ik zat te denken om dit goedje over de bestaande slipbandjes te doen, zodat de rails minder vies wordt, maar wel de trekkracht behouden blijft.
Gr, Mark
Duitse tramstad in H0, een speelbaan in spoor 0 en een nieuwe beursbaan in 0e
Jos001
  • N en G rijder
Re:Snot!!!!!
« Reactie #5 Gepost op: 06 May 2010, 21:17:35 »
Op het N-spoorforum heeft er ook iemand ervaring mee, is erg enthousiast. Zie link hieronder (even doorscrollen naar beneden).
http://www.n-spoorforum.nl/phpbb3/viewtopic.php?f=18&t=1349&start=30
Groetjes,
Jos
N-spoor, digitaal met TC
G-spoor, digitaal met LGB-MZS
Tomasso
Re:Snot!!!!!
« Reactie #6 Gepost op: 06 May 2010, 22:40:34 »
Dat is misschien wat voor mijn loc...
Spoor 0 adept
Re:Snot!!!!!
« Reactie #7 Gepost op: 06 May 2010, 23:52:06 »
Bij dit soort dingen is de eerste vraag die bij mij opkomt: wat voor spul is dat eigenlijk?
Het moet wel iets heel bijzonders zijn, een potje van nog geen 30 gram voor 25 dollar.
Jos001
  • N en G rijder
Re:Snot!!!!!
« Reactie #8 Gepost op: 07 May 2010, 00:15:10 »
Probeer zo'n potje maar eens vol te krijgen  :-X ;D
Groetjes,
Jos
Matheus 18
  • Nog iets te plat voor Profi.
  • poging tot Steentje bijdragen.
Re:Snot!!!!!
« Reactie #9 Gepost op: 07 May 2010, 08:44:30 »
Alweer een Amerikaan die het warm water heeft uitgevonden, de commerciele weg heeft gevonden en denkt rijk te worden.
Een echte vinding is dit nu ook weer niet, haal gewoon in een aquarium winkel een tube aquarium kit (doorschijnend cilikonen) en je hebt het zelfde resultaat.
Zo simpel is het.
Matheus.
  • Nervensäge.
    • belse roestkraam
Re:Snot!!!!!
« Reactie #10 Gepost op: 07 May 2010, 08:51:10 »
en zie het spul er dan maar es gelijkmatig op te krijgen, anders hobbelt de loc meteen. Wat is er zo moeilijk aan ff een groefje in een wiel draaien?
Jeroen Water
  • NS tijdperk IV (1973/1974)
Re:Snot!!!!!
« Reactie #11 Gepost op: 07 May 2010, 08:58:53 »
Op deze site laten ze duidelijk zien hoe het werkt. Erg simpel zo te zien.
http://www.bullfrogsnot.com/pages/How_to.html
Voor lang niet iedereen is het even simpel om een groefje in een wiel aan te brengen. Bovendien leveren rubberen anti-slipbandjes een vervuiling op de spoorstaven op.
Eenerspoor
  • D813 Groningen 1972-73 grijs verleden met karakter
    • MSC-Roden
Re:Snot!!!!!
« Reactie #12 Gepost op: 07 May 2010, 09:01:05 »
Zo simpel is het.
Heb je daar ervaring mee?
Henk
H0 2-rail met  iTrain, Yamorc 7001, Digikeijs, Rosoft, LocoNet.
Eenerspoor
    • MSC-Roden
Re:Snot!!!!!
« Reactie #13 Gepost op: 07 May 2010, 09:02:53 »
Nou, als je geen draaibankje hebt en niemand kent die er eentje heeft.... :-\
Henk
Matheus 18
Re:Snot!!!!!
« Reactie #14 Gepost op: 07 May 2010, 09:30:39 »
Met een tandenstokertje wat aanbrengen op het wiel dat eers gereinigd is met wasbenzinne en droog is, vet kunnen we niet hebben.
Breng het een beetje gelijkmatig aan.
Neem een stukje rechte rail voorzien van stroom, plaats locje op de rail, Voor N 2cm vooruit rijden, voor Ho 3cm.
Direkt het overtollige silikonen verweideren van de zijkantjes wat uitpuild, eens droog trekt ge gewoon alles van het wiel terug af.
Laat siliconen een 12 uurtjes drogen, als je met je vinger over het wiel   wrijft word je zo al een tegenwerking gewaar.
Kunt hier ook de rubber bandjes mee veranderen, slechts een tegelijk en telkens laten drogen.
Wanneer je deze gelijktijdig doet krijg je nooit een gelijkmatig vlak, inzakken van het wiel over de rail enz..
Eventjes vergeten te melden, rail inwrijven met een drupje puur zeepsop of afwas middel, anders plakt siliconen ook op railstaaf.
Matheus.
« Laatst bewerkt op: 07 May 2010, 09:36:28 door Matheus 18 »
